Aspect Ration locked in to Camera
I’m not sure if this is something that already exists, if it can be made to exist through VRay or maybe it is something that 3DS Max needs to work out or if there is a plug-in anyone knows about (and not have to use SceneStates which is painful).
I’ve run across needing to change the aspect ration depending on the camera angle for some of my renderings. The problem is that I forget I did that, and so I end up rendering and having to re-render that camera angle because I forgot to change the Aspect Ration. Is there a way to change the aspect ration for a camera only, not the whole file? That way I can set each camera with the correct aspect ration independent of the overall file.
Tks!
Hi Pedro! Pulze Scene Manager looks like a solution for you. Take a look over here: Scene Manager - The Staging Tool for 3ds Max
Cheers,
Attila
10 years of use. never failed me. simple and reliable.
Downloaded it last night, started playing with it. Impressed at first sight! There are some things that I’m trying to understand about it yet and the region option did crush on me twice, but otherwise I find this to be quite AMAZING! Over the last three days I have been doing soooo many changes to a scene that had two different aspect ratios and of course would mess it up, so this would have been invaluable. Thank you!
Another vote for Batch Camera Render. Couldn’t live without it. Would love to see something like this for sending renders to Chaos Cloud.
Something also awesomely great that seems to need some development in there is MFRender. It seems to send to render different max files? It seems like it is compatible or being made compatible with Batch Render, so that you can send several files with pre-sets for each camera you wish to send… from one maxfile. So… for those bigger production companies (not mine), you should be able to do a lot more production in an even more streamlined workflow. Specially when you have several groups of people working on one project. I don’t use Chaos Cloud, but it does seem to be a good idea of them to dive into this.
