It’s a very common workflow in small studios to share mapped drives as the location of assets - however, for some irritating reason, Cosmos seems to know that this is a mapped drive and wont let me use it as a download directory.
Please fix this, and also fix it so that you can choose a folder with some kind of dialogue instead of copying and pasting a file structure like a cave-man. This is basic programming UI stuff guys!
Hi JD3D_CGI,
Our guess is that if you restart your machine, the above will start working as expected, and you will be able to select the mapped drive.
More explanation behind the restart requirement was given in this ticket .
Apologies for the inconvenience. Write to let us know if problem persists.
That did work - thanks. I had updated and restarted, and this was starting the machine for the day… but… if it works it works! thanks again!
