Asset Edtior - Error when editing material
Greetings,
I’m encountering the following issue (see attached) while trying to Edit material in asset editor. This issue triggers other problems, such as impossibility to edit other materials, they’re missing from the list, also Sketchup is freezing.
Software used: Sketchup 2023, Vray 6.10.01
Thank you in advance.
Hi, victor_lupoiu
I’m afraid I’m unable to reproduce the problem described.
Could you please confirm if you are experiencing this issue with a specific project and materials or newly created ones?
The quickest way to help you is by looking at a scene showing this problem. You can submit it either by attaching it to your forum reply or by opening a ticket.​
Kind regards,
Natali Velcheva
