ASSET ENSCAPE DON'T PLACE OBJECT
Hello, I have installed the latest available version 3.5.6+204048 on Rhino 7.
When I click in the application bar “asset library Enscape” everything opens correctly, I select any element, it tells me to select a surface, then specify a point (in this case however I already don’t see the selected object) and then nothing appears… any object selected from the ‘asset enscape library’ cannot be inserted.
Otherwise if I enter the Enscape window and insert any object from the “asset library” it works but the process is very slow.
Could I understand why?
I enclose screenshots of the commands
Lorenzo
Hey @STUDIO_TETRIS , please send us log files as described here, so we can analyze the possible cause of this issue: https://learn.enscape3d.com/blog/knowledgebase/using-the-feedback-button-win-rhino/
