Several people have asked to get the library in Revit format.
I like the workflow to open up a file select the assets that i need and copy them into my project.
This way i work way faster then going through the asset library menu each time.
Unfortunately is Enscape not willing to give us these kind of file.
So we have to do it our selves.
I have started placing the objects in Revit files and tried to group them. (Revit 2020)
So far i have done 4 categories and will do the others as soon as possible, links will be provided below.
There will also be one container that rules them all..
sitting people will be divided in 3 categories 415, 485 and special..
the sitting height is based on 415 or 485… the two cubs in front can be used in chairs and benches
the cubs have there own subcategory so can be turned off in views..
These cubs will be placed in the street furniture and normal furniture.
The cubs together with the comment in the people asset 415 or 485 will trigger the dynamo script to place people on chairs and benches..
@Demian, that is not the anwser i got from support
so it is to much time for you guys..but it is fine when a lot of your clients need to do this work on there own.. And with a simple script all assets could be placed in a file. Would not take more then 2 hours to write some code and place it when you have access to the source code of the library.
But i will spend more then two hours of my time to make this and share it with the community..
@arno_delange - well, we have already invested a lot of time to provide these assets, and we are still working on creating more. We hope to have at least doubled the current amount by middle of next year, and that’s a lot of effort.
But, I take your point and will pass your feedback on to the relevant people here at Enscape for them to consider.
So, it’s not that we don’t want to provide this, it’s just we have not, as of yet, found the time to do this on top of the other more pressing things that need working on to keep Enscape ahead of the game.
Of course we, and obviously other Enscape users, completely appreciate the effort you are putting in to provide this resource, and in that respect, as mentioned, I will pass this on for it to be, in the very least, considered in regards to how the Asset Library goes forward.
I understand the workload and as a community we are happy to do some work. Love the new 2.6.1
As i stated in the ideas area of this forum as well, please at least mark the new items as new..
now i have to go over all of them to see if they are in my project or not.. if they are marked i know which ones to add an can update the file more easily
For what its worth, I went down this road with Archvision content a couple years ago, making individual revit families for each RPC. took forever and in the end I don’t think many users took advantage of it. And they keep making new content so keeping up with it is hard. So I can totally relate to you desire and frustration. It would be great if they had an easy way to provide this, but as the library will keep expanding(thank you Enscape!!!) you should be prepared to keep up your effort with each release. Or just leave well enough alone with the asset browser, because the 2nd problem I ran into is now you have to make your revit families available and searchable for your users, when enscape and in my situation archvision had already done this. I hated the naming convention when content was loaded, but at the end of the day I feel like it was a big waste of my time, however I knew what all the content was really well.
Because the library is expanding the download time is going up expensivel… the library really needs an offline version that can be synced.
@sdbrownaia i understand the problem and i am also running low on my time to do this. For me the workflow of going into a file grab everything i need and paste it into my working project saves a lot of time, i just provide these files because other people don’t have to create them. I will try to update as much as i can, but help will be appriciated then like you stated as well, these should be files Enscape provides. Whebn you have acces to the code it should be easy to write a script that places all assets into a revit file… should be 15min of work instead of the hours that i have to spend. But they are short of time as well, but i do think they don’t see the importance of this. It really helps our workflow
