I on numerous projects have had this issue, but never really gave it a second thought until a few projects recently when my use of third party models, etc came into play.
Basically I always have “show missing maps/files” checked in the vray system, so that it notifies me if there is anything missing; particularly useful when network rendering. The problem however is that the message is usually incredibly cryptic, such as: “ä referenced by ô”. What the hell is that?!
Invariably I am finding that this is caused by the maps in question being within a VRay Dirt map, and for whatever reason the software can’t read the names from within it. This is incredibly frustrating on large projects, causing me to have to go through every texture to manually find out where the missing maps are.
On Max, relink Bitmap works pretty well. No more manual tweaking anymore. Relink Bitmaps - colinsenner LLC
But I’m pretty sure you are aware about it already.
As a side note/question to you chaos guys:
How many of these features/fixes will you put into the existing 2.40.04 version?
I was hoping most and that you basically put all new features and fancy toys into 3, but let the rest og us actually get these bug-fixes as we might not be able to upgrade yet.
We do push some of these to the 2.40 branch, yes. If you check the nightly builds site, you will see that there are builds for V-Ray 2.40 and they are occasionally updated - the fixes will go into the next 2.5 service pack.
I would love to have an automatic update system so VRay just gets updated across our farm with one click. It’s the ONE thing Vue is very good at, you update the license server and all the slaves update automatically.
Current project folder is “C:\Users\vlado\Documents\3dsMax”
[2014/J/27|05:57:12] Checking for missing files.
[2014/J/27|05:57:12] warning: The following files are missing:
[2014/J/27|05:57:12] warning: “G” referenced by “s”
[2014/J/27|05:57:12] Entering beginSequence().
cannot locate “G” or “s” using the typical methods.
this is really killing current job. Using latest stable build.
I do have a python service for updating alls the plugins in all our workstations and slaves, it still has bugs (the services sometimes stops, and i didn’t have time to correct it).
It allows ini updates, env vars setting and reading, registry reading, vrayspawner use detected and 3dsmax use detected, so it only updates if no session of 3dsmax is open. It stops and restarts the spawner.
If i have time i setup a github repo for this, maybe some wants to contribute.
The fix for the messed up missing file names has been for a while in the V-Ray 2.0 nightly builds. It will be available in the stable_2.4 from tomorrow on.
