Suddenly some of my assets appear without material, it is not all of them but some. Did some renders in the same file earlier, but it rendered fine.
I haven’t changed in the blocks or anything.
Hope you can help.
/David
@davidjessen thank you for reporting this issue! We’ve seen a couple of people having this problem but so far we’re unable to identify the root cause. Would you be so kind to send us a dedicated Feedback so that we can take a look at your log files?
Also: Does this only affect people Assets or Assets from all categories?
Thanks for a quick reply. It seem only to be people (not all of them), but I haven’t checked everything. Threes are so far working fine
Talked with the development department, got this reply witch worked
Deleted this folder, and restarted Rhino:
“C:\Users<USERNAME>\AppData\Local\Temp\Enscape\Assets\Data”.
This will ensure all data is downloaded again and should fix the issue.
Exactly. That is currently a solution which should generally resolve this issue.
Thanks for sharing!
