Assets from Chaos Cosmos only render in black
Anything I download recently from Chaos cosmos (here: people and furniture) will only render in black.
Two days ago I was not having the same issue — as you can see some of the assets are fine.
The assets renders properly with sunlight, but does not with Vray lights:
With Vray Lights:
With Sunlight:
Here is the project file:
https://drive.google.com/file/d/1C41…ew?usp=sharing
Any help would be greatly appreciated!!​
Hey,
Thanks for the scene! I just tested it and it seems to render correctly - no dark Cosmos assets on my end.
Could you tell us which are your exact V-Ray and Cosmos versions? The version of V-Ray can be found in Extensions > V-Ray > Help > About. The Cosmos version is located under the tree point menu in the right corner of the Chaos Cosmos Browser > About.
Thanks!
