Thank you for notifying us of this issue. The error message you are seeing indicates that our assets cannot be downloaded. Are all four machines you mentioned using the same internet connection? Can you please ensure, that you have a stable connection while starting Enscape?
If your internet connection is working fine, you might have a firewall enabled, that blocks you from downloading our assets. In that case we’ll provide you with further details on how to allow our services to be accessed.
@regiph Yes this could very well be the reason. If your technical colleague does not know this already, our GetStarted page contains all the information necessary to configure your proxy/firewall.
I hope this resolves your issue. If not, please don’t hesitate to contact us here, via pm or via feedback again!
Just ran across assets not showing up this morning and wanted to share the fix I found. On my plan I put an in-place component for a flooring pattern on top of the concrete slab. This pattern was 1/8" thick, so what was happening is that the assets on the floor were attached to the “level” and wouldn’t show up because of the flooring pattern being “above” the base of the asset. I just raised the asset up 1/8" and there they were!!!
