Assign material to different faces throuhg asset editor
i knew it wasn’t possible to assign different materials to subselected faces from the same polysurface. I usually had to extract each face and assign the material.
today i realized that if i subselect the face and assign the material not from V-ray’s asset editor but Rhino material tab it works.
is there any plan of adding this abbility to V-ray’s asset editor?
thanks
that was pretty easy to implement. There is one small caveat if you don’t have preexisting selection, but I think that is a very rare case.
Also it won’t work in Rhino 6, since there is no such API there.
Bottom line : it will be available in the next release
Cheers
