Assigning RT - Next1.1
Just noticed if I change to another RT renderer in the assign renderer rollout, then V-Ray is no longer in the list to pick.
Is that supposed to be this way? Other than restarting the scene I see no way to re-assign V-Ray for the real time rendering choice.
I would make a screenshot, but I don’t want this to happen in my current scene. Thanks.
Not sure what you mean.
Just set V-Ray GPU as production render. There is “Start IPR” button in its settings - use that instead of active shade, etc.
Best
Blago.
Okay, so it is normal? Just ignore the active shade option for Vray Next?
Thanks a lot savage309.
Yes, active shade is not used anymore in Next.
Use just one render mode - Production. You can still use interactive rendering by starting it with the “Start IPR” button.
Best,
Blago.
Thanks again!
