I got several beeps and had a long mail contact with the support at Supermicro.
With no solution and me afraid of ruining an expensive workstation, I panicked and bought a new motherboard hoping that that would solve my problem.
So I ordered an Asus Z10PE-D8 WS motherboard, installed everything again and STILL getting F/&¤%#% beeps!
So I have for the last hour tried ram-memory module one by one, sometimes I only get one beep and sometimes 2 beeps followed by 1 beep.
I have also updated to the latest bios.
The beeps are 2 short beeps and then 1 short, more high pitched beep.
Yes I went for the manual as a first solution my specific beeps is not in there, I have built several computers without any problems until now.
Everytime a started the computer it finds the memory modules, all 8 and also one by one. And yes all the 8 modules are being read, in windows it says 64gb (63,9gb usable) and when I boot it says 65536mb ram.
Besides the beeps everything feels slow, POST shows up 2-3 times before starting to load windows and windows 8 is booting up way slower (like twice the time) than my i7 3930k with windows 7.
No errors, everything it working except those beeps and that it feels slow, and it shouldn´t beep at least!
What do synthetic benchmarks say about performance ? Does for example Passmark record the score you would expect ?
I only remember beep issues when the board struggled with particular memory setup. For example my asus z9pe-d8 ws never really accepted the memory at 1600 at correct timings, forcing me to lower it to 1333 despite it being “officialy” supported.
Since you have 2 shorts and then one short, could perhaps the issue be in those first two ?
Ie: first “short two” – HDD Issue
second “short one” Can’t detect keyboard (not really issue at all since Windows will, I think I have this on few PCs )
No, it’s very fast. Of course, not as fast as i7, since these boards have far more features that get to load, but still very fast, I would say sub 20 seconds into desktop ?
Windows 8.1, 840Pro Samsung SSD.
UPDATE: Okay so now I removed the previously used SSD and only had the second one attached. I installed Windows 8 on the second one (it seems like the Windows 8 installation is different every time I do a clean install?) and now I get the following result:
Only one beep with a boot-up process like this:
0sec to about 38sec - first now does the monitor turn on (seems like a very long time?)
38sec to about 49sec - first POST messages shown (one shorter message and then the computer specs)
49sec to about 60sec - second POST messages shown, again one shorter message and then the computer specs
After that it shows the Windows 8 logo and loads for about 3-5sec before I get the login screen.
Thanks for trying to help! Yeah I´m not a big fan of troubleshooting.
I will try to sort this out and also contact Asus.
At least the first 2 beeps are gone and Windows 8 loads in seconds when I switched SSD drive so thanks for that tip!
I got my money back for the faulty SSD so I ordered a Samsung 850pro, and will use that for the OS and the other one for local projects
I can keep you/this thread updated regarding the answer I get from Asus, if you run into the same problems with your motherboard but hopefully everything will work!
That sounds great! I will use the Samsung ssd for OS and the OCZ for ongoing projects
It´s an Geforce 980 GTX card (Gigabyte GV-N980G1 GAMING-4GD) and it should have enough power since I´m using a Corsair AX1200i Power Supply?
I will try to re-seat the gpu to another PCI-E slot and se if that makes any changes. I put it on PCI-E slot 3 to get it away from the Noctua cooler a bit
No absolutely fine, 1200i is super overkill for your machine, you might as well get 3 GPUs :- ) and still be fine. But did you connect all the necessary power connectors, to correct voltage slots in PSU ?
I know by 99perc. you did, but sometimes this can be confusing and mistake is easily done as PSUs often don’t label which slot has with voltage.
Tried re-seating the graphics card without any change, still the same problem.
Also the graphics card fan is spinning fully(noisy) when starting the computer all the way to the login screen where it settles down and becomes almost totally silent.
Perhaps the graphics card is not fully compatible with the asus motherboard?
