asus z7s ws and 2 ultra 120 extreme will it fit?
Does anyone know if I will be able to fit two Ultra 120 extreme coolers
http://www.thermalright.com/new\_a\_page/product\_page/cpu/u120ex-1366rt/product\_cpu\_cooler\_1366rt.html
on Asus Z7S WS http://www.asus.com/product.aspx?P\_ID=tjBioAZTBRuSpOHj&templete=3
to cool two Xeons 5430 ?
If not what coolers woudl you recommend for such rig?
I guess that those xeons won’t come in retail box with active cooling?
i would not go with asus in the 1st place :slight_smile:
so what would you recommend that would fit into standard (not server) pc case . I got silverstone TJ09 http://www.silverstonetek.com/products/p\_contents.php?pno=tj09&area=usa
you should be ok, but you might not have much clearance between the case and the top of the cooler/fan.
Do you have the stock xeon fans/heatsinks?
no I don’t. And I never had xeon based rig so I don’t know if they come in retail boxes with heatsinks like standard intel cpus. Right now in this case I have one 120Ultra on Q6600. About the mobo… Is Supermicro X7DWE ATX better than asus?
http://www.supermicro.com/products/motherboard/Xeon1333/#5400
Or maybe TYAN but as I can see only Tempest i5400XT (S5396) supports windows and quad and I think it doesn’t look like standard ATX.
http://www.tyan.com/product\_board\_list.aspx?cpuid=1&socketid=10&chipsetid=99999
Noctua NH-U12P SE1366
For what its worth I only just got a Noctua heatsink to fit in my new standard cased PC, so measure 3 times cut once…very quiet and good cooling though.
laters
spike
