ASUS Z9PE-D8 WS + 2x E5-2690 doesn´t boot
So I thought, that bulding new station with ASUS Z9PE-D8 WS will be easy, but it´s horror…
I have new 2x E5-2690 cpus, 8x8 GB ECC REG DDR3 1600 memory, ASUS Z9PE-D8 WS, Corsair HX1200i psu /EVGA 850 G2 as backup/.
After 8hours of trying I was able to see bios only in begining, cpus and memory were correct displayed there.
Rest of time I tried to reorganized all, changed cpus, memory modules, psu cables, sometimes I have seen q code, but rest of time I´ve seen only
power button and reset button luminous. Pressed power button, nothing happened, sometimes q code.
I try everything, 1 cpu-1 mem module, 2cpus-2 modules, 2 psu, exchange cpu postions, but nothing helped.
There is a lot of posts with problem with this board, there is my problem, exactly:
http://vip.asus.com/forum/view.aspx?SLanguage=en-us&id=20120405093230054&board_id=1&model=P5E3&page=1&count=27
Do you have same problems? What shall I do?
in my case update bios to 5802 make the deal… but i have another issue after that…
i read that in some cases gpu is holding post/boot to pass
It doesn´t boot to bios, so I can´t upgrade it.
If it’s any help, you can order another bios chip. I always kept two in case newer bios failed somehow.
Can you borrow other memory sticks? Just to be sure.
Seller give me new mobo, so I try my memory and try to borrow some memory.
I bought this, one guy bought it there as well, so it shloud work:
http://www.ebay.co.uk/itm/8x-8GB-64GB-RDIMM-ECC-REG-DDR3-1600-MHz-RAM-Asus-Board-Z9PA-D8-Z9PA-U8-Z9PA-D8C-/361782370872?hash=item543be8e238:g:YWsAAOSwPhdU0QH0
i bought them, they work fine!!
so memory should be ok… I´ve just worried about temp of E5-2690. Bios showed me 60 and 50 degrees without stress,
it´s really high temp, max tem by intel is 72 degree…
Is anybody there who use E5-2690 cpus?
what cooling are you using on them?
NOCTUA NH-U14S
your’s temps are a bit high…
NH-U14S, the same as i have… i know that i have different cpu’s but my temps are like 30-35 (difference between cpu’s like 5-6) in stress it’s 55-65, but max is 80… TDP 115W…
I check temps on new mobo, it should be lower…
