@Maarsso , thank you for your post. I’m afraid, there is currently no direct way to remove the ground plane from the “Clear” preset, but, you could make use of the workaround provided by @Micha above , or try the following:
Use the Export Material-ID and Depth option (in the Capture tab), whereby the depth is an Alpha channel. You have to set the depth Range correctly to get your desired Alpha channel, then use something like Photoshop to composite the image in post.
If you want me to file a corresponding feature request to allow for an easier ground plane removal, please let me know.
…hello everyone - I’m sure I didn’t understand something correctly - but for a job like this, wouldn’t a HDRI environment be the best choice? maybe any “open see” or “beach” HDRI
I will not work. If a HDRI is shot 1m above the ground than it will be good looking only if your virtual camera is 1m above the virtual ground. So for example you can’t shot a bird view of your scene.
I’m a genius! I figure it out how to remove the grey horizon using water/ocean/grass without using a sky box. Ready? In Revit, make a shape component using the blend tool. Note, you can not make a hallow shape using this tool so the top loop and the bottom loop need to be cut and joint as the images bellow. Then you make a slight cone where your subject is inside the cone (lower smaller ring of the cone and the horizon is the ring of the outside top part of the cone. (Just like a paper cup cone that you find with the water dispensers) Then make the outer ring really large. The outer ring has to be just slightly higher only otherwise it looks like a Tsunami is about to hit the coast. LOL If you have any questions about it, I can explain better but if you know how to use Revit, this information should be enough. Enjoy your new grey ground free horizon!
Forwarded your upvote. At least for now there are no plans to change the bottom parts of our horizon presets. They are designed like that on purpose and we usually recommend using a dedicated .HDRI file of your choice if you wish to have a different ground appearance. Just mentioning this to not raise too many hopes.
I have also made a similar request - about changing the horizon height within the Skybox settings. This is a simple adjustment that is found in more DDS tools . For example, in 3ds max - Vray you can enable ground projection which allows the camera to look directly down and render with zero distortion or you can adjust the coordinates such as the vertical direction to offset the horizon line
I get around it by placing my model inside of a shallow dish (which is textured with “water” (although you might need to put a second layer to stop seeing through it )
