Hi. As the tittle says, I’ve found that with Corona 1.5 daily build 2016-06-12 atmospheric fog doesn’t render in IR - but it does render fine in regular render. This is quite inconvienient since it makes the fog set up much more tedious.
I’ve tried it on both max2014 and 2016 with similar result. I’m not 100% sure if this is a bug or when it was introduced, but IIRC I’ve used the IR in previous versions when setting up atmospheric fog.
I’ve ttached a picture showing the case.
Regards
Edit: I see that I’ve posted this the wrong place. Would someone please move this to Daily Builds. Thanks.
