Is it possible to get the Enscape atmosphere to show in reflections? Being able to set a real world location to asses glare internally is great, and we’d also like to use it externally to assess sun reflections, e.g. I’m approaching the building from a particular angle, is sun reflection an issue for pedestrians, drivers etc.
Hello @ColinMagner , thank you for your message!
I’m unsure what exactly you wish for. Please let me know in case your question is not answered hereby.
- Atmosphere showing in reflections - I suppose you mean sunlight and clouds being reflected? That certainly should be the case:
Is there anything particular you’re missing to see in reflections? Enscape will never get ‘blinded’ by the sun, but as you already said, if you’ve set a certain location, date and time, Enscape will display the sun/shadow angle correctly depending on where you are on the planet, no matter whether you’re inside of a building (given there’s windows), or outside.
Hi Kaj,
Your image is exactly what I was wishing for, thanks! I’ll have a look and see what’s going on with the materials in the model I’m using, because currently there’s nothing being reflected.
