Attaching objects into one changes their material appearance
I came upon a strange thing while attaching my objects into one. A particular object’s material changed appearance. I’ve checked the materials IDs after attaching and they are all fine. If I detach it to separate objects again, the material changes back to the original look. Please see screenshot below.
Not sure. Could you strip down the scene and attach it here or send it via the contact form? Address it to me in the subject and include a link to this thread in the message.
Sure, see attached.
materials_issue_attached_vs_detached_max2022.rar (132 KB)
I saw something similar recently. Didn’t have time to diagnose it, but it almost looked like the attach had messed up the smoothing.
Thank you for the provided scene. The issue is caused by two things - the Rounded corners on the big cylinder and the refractiveness of the small cylinder. I am not yet sure if this is a bug or a byproduct of the rounded corners’ effect. I’ll write again with more information.
EDIT: Setting the Rounded corners mode to Convex only resolves the issue, so you may use it as a workaround.
