All comentaries are welcomed
By visaton at 2008-03-20
Re: AUDIO SYSTEM
Hello Alexander,
amazing work, very nice work on modeling and materials, congratulations!
the only thing that looks a little to “clean” are the chrome feet of the unit, maybe a very subtle amount of glossiness would help…
best regards
Andy
Re: AUDIO SYSTEM
Looks very nice.
If you like to work on the scene … I would:
- add small fillets to edges without fillet
- setup a background
- refine the look of the LEDs (best take a photo of a real world LED, change the color in a photo software and use the texture for an emitter material - a little light gardient should be visible and can be very nice looking)
- model less sharp edged feet, that makes prints in the wood and scratch the ground ![]()
Re: AUDIO SYSTEM
I feel, some metal edges show no reflection - for example at the third image the big volume knob. The big fillet around the lower device show a bright reflection and I miss it at the knob. But maybe the reflection is very small and not so much visible.
Re: AUDIO SYSTEM
Fantastic!!!
I would love to see your setup if possible.
What kind of hdri map
what kind of settings
What kind of lights
Is it possible to recieve this file…i understand if the product is confidential…you could remove the geometry and just send the file with the settings and light set up…would be really appreciated. Its the first real product shot (industrial design - not counting jewelry) that i see here in the gallery.
Thanks so much
E-mail - jwagemakers@blueskycreative.com.au
Thanks man…like i said…awsome work.
If you dont feel like sending…could you post your settings?
cheers
Re: AUDIO SYSTEM
This looks terrific, you should submit it to the gallery!
Re: AUDIO SYSTEM
Micha you’re absolutely right ;). I’ve tried to filled this edge many times, but every time geometry of the knob was failed. Many artifacts was appeared, and i was giving up :-[
I hope that the last images are better than previous.
Shopper, i’m glad that you like my work, many thanks ;)So this project is not confidential, and i will send you whole file.I’m studying industrial design in the university, and it’s my passion. Unfortunately in Bulgaria, is very hard to find a job in this sphere, but i’m not giving up ;D
