Auto Save and Render Queue directly from Corona Buffer
Hi guys, working in a big production office we are always rendering multiple scenes nightime on the same machine.
We are currently using a nice plug in called PV Render Queue to set a list of scene to be renderer, but we would love to have the feature inside Corona. Hope is a possible feature to be implemented.
Our major problem right now is that rendering multiple scene at once, oblige us to set up the autosave from C4d (instead of manually save from Corona Frame Buffer) and that causes an incorrect output of Color Profile when going into Photoshop. The color profile of the image and the multipass from C4d is Linear and when replaced with the standard srgb in Photoshop, tones down all the passes of 0.4545 gamma (inverse gamma) and obliges us to restore it with a 2.2 gamma causing color data been lost.
Is there any chanche you will fix that, we had the same problems with Vray for C4d in the past and the guys implemented the translator to avoid using C4d native autosave and letting us save separated passes with the correct gamma.
Thanks for the support!
