I need to import a dxf file into max. It’s pretty big and when I import it, the whole scene consist of only a few big joined meshes. Half of the building for example is 1 mesh. I don’t know if there’s a problem in the dxf or in the import process into max.
Someone has some experience with dxf files in max to give me some tips for successfully importing it?
Can you open the file in autocad? if the objects are on differnet layers, I think you can ask mask to creat one object per layer. If not, ther’s nothing you can do about it… unless they are blocks w=hich then can be converted in different objects on the import in max.
I now got the file in max with every object as a seperate part. I saved it as 3ds and got it into rhino, because rhino is much easier for selecting every part. I need to delete all interior parts because only exterior renders are needed, so I’m cleaning up the file inside rhino.
