Automatic naming
Hi guys, great software, just a little request to make saving images in Archicad21 a little less cumbersome.
The automatic naming includes ‘Enscape+Date+Time.jpg’ but i have no need, when sending JPEGs to clients for example, for there to be ‘Enscape’ in the name. In face the information in the name is quite crucial in architecture to ensure everyone is dealing with the latest drawings. I remove it every time and replace it with the project name, which i paste into the file name of every image.
A custom field that allows us users to replace that bit of text would be an awesome change.
Also, maybe a couple check boxes for the date and time so you can compose your automatic naming to something useful to you. For example, the time isn’t always needed.
(Similar request here: Capture and Customization options)
+1
+1
Thanks a lot for the post @davidstone and thanks to everyone else for the further feedback. :slight_smile: This has been requested before, so it’s on our agenda already filed as a feature request. Just added +4 to the story accordingly through your voices.
Since it is not possible to vote on “public voting portal”, here is my vote! +1
first request was made in 2018… its been 5 years and still have to manually rename every render X/
Get Microsoft powertoys - power rename tool to change all your files in one easy run. I use it to batch change all the files as complained about above.
https://learn.microsoft.com/en-us/windows/powertoys/powerrename
thanks for that suggestion, the renaming powertool is definitely a convenient enough solution so that will do for the time being :thumbup:
if only this wasnt a necessary workaround and was just built into the features for Enscape with Archicad.
up
+1
Yes, this is a real letdown, especially given the cost of a license.
We need a flexible way to manage file naming from within Enscape. I’d like to see something similar to UE’s move render queue mechanism. I want to be able to create output configs and attach them to items in the render queue. Each output config should let me specify which visual preset should be applied to the related render and separately where I want to save the render output. The output path should be fully configurable with keywords that will be automatically substituted with relevant values at output times. For example, $day, $month, $year, $scene, $shot, etc.
I’ve been thinking about this some more and here’s what I came up with. It’s best illustrated with a diagram. Take your time to go over it, I’m proposing a few changes and file naming system comes at the end.
I believe that these changes would actually make it easier to use Enscape and certainly would help manage batch export process. I’m happy to discuss this further with anyone who is interested.
Here’s the diagram in PDF format:
Settings UI and functionality.pdf (5.98 MB)
And here’s a pretty picture to help those who don’t like clicking on links:
