Is there any way to automatically save the frame buffer contents if it detects the shutdown or restart processes are running? Recently I’ve left renders overnight and came back to a nice windows update and no render.
If this isn’t something within corona itself, would it be scriptable in maxscript?
There is autosave already. You can find it at render settings>system>frame buffer>output autosave.
im aware of the autosave feature. Im just wondering if its possible to dump the render to file if a shutdown/restart is detected so it can be resumed when you restart. and if so, does maxscript have access to the necessary functions to do this with corona?
Jack
Why do you want that? No script will save you in a case of power outage or max crash.
I think what he means is to save when there is a proper shutdown, not a crash. For example if you press power button on your PC, usually in such case 3ds Max pops up a message like “please save all your work before shutting down” and the shutting down process is paused for some time. He would like to have this done automatically.
yeah basically i leave renders overnight sometimes at work and the windows updates restart the pc sometimes. i cant disable them due to the security policy. im wondering if i can script something that will detect the shutdown process and dump the render to file or even just save the frame buffer contents just incase.
essentially, is there a maxscript call that will allow me to use the save vfb function via script?
i guess thats a no. Is there any maxscript documentation for corona?
