I just installed the free version of Corona Alpha 6.1 for my 3ds Max Design 2014.
Installation went well, but as soon as I am trying to start 3ds max, this error message shows up (see attachment screen1.jpg)
Let me try to translate:
The entry point of the procedure “?avgSunColor[…]” was not found in the “Corona_Release.dll”.
After I click OK, this shows up a several times: (see attachment screen2.jpg)
“Error code 127 - The given procedure wasn’t found”.
Then, 3ds max starts, and as soon as I try to render, the “tools” / color mapping is not available in the vfb. (see attachment screen3.jpg)
I apologize if this is a duplicate but I couldn’t find anything via search.
Have I done anything wrong? Installation seemed to be OK, and previous versions of Corona worked flawlessly on this computer. Problem persisted also after restart.
Thank you very much in advance and a BIG UP to the whole corona team I totally love you guys for making such a great product!
Hi, use the uninstaller ( https://coronarenderer.freshdesk.com/support/solutions/articles/5000534885 ) and then try installing A6.1 again. This error usually pops up when you have wrong files installed - for example for different version of 3ds Max or when using files from different versions of Corona at the same time.
