Avi darkness
Hi
When rendering out an animation from the Ram Player - the final avi outputs somewhat darker than the original. When it is output to an .mov - its fine.
Does anyone know whats going on?
N
Yeah i get the same problem … probably something to do with compression ? … i would like to know the answer as well ..
This is when using the Intel Indeo codecs - I normally use the huff codecs but mainly for final compression as they create massive files.
one of the tricks that compressors use is to darken and brighten footage so that the darks get crushed to black and the lights burn out to white so it can compress block areas of the two really heavily. Only way to do it is use a higher quality compressor like sorenson 3 under quicktime or xvid for windows.
Avi’s use videocard overlay - Quicktime doesn’t. Use your GfxCard video overlay settings to adjust
Also described here:
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=14118&highlight=quicktime+avi
A funny thing about saving movs from RamPlayer - select any other codec than Sorensen (mpeg4 f.ex.) and save… Select once again another codec and save… Select another compression and save… Then compare the files!
Fun.
Regards, Michael
