AVOIDED innumerable CRASH WITH the use of V-ray Raw Image File
Hello guys, I do not want to explain any procedure here but simply give you a tip that, ACCORDING TO MY EXPERIENCE, IS FUNDAMENTAL!
use the output vrimg, use the output vrimg, use the output vrimg, use the output vrimg,
there is also a GUI if you prefer clicking that, writing
http://binka.biz/?Download …>>>>>>
Re: AVOIDED innumerable CRASH WITH the use of V-ray Raw Image File
The linked site is not english. Can you explain what this app does?
Its just a gui for the vrimage converter. If you don’t like dealing with command lines, then it might help, but it doesn’t add any functionality. The easiest thing to do is when you click on a VRimage, windows will ask you what application you want to open it with. Point it to the vrimg converter and select always use this application (or something to that effect), and you probably won’t have to touch it.
hmmm nice… now I only need to know WHAT IS and HOW TO USE the VRIMG…
sorry for bumping up an old thread…
i have a question why, this method didnt work out for 1.48.96 version?
i used vrimg output but it render with full resolution in vfb not like the previous version where it render in preview (smaller resolution)..
so am I doing it wrong in vray 1.48.96. or there is another way to avoid crashes i want to render in high resolution?
use the exr format rather than the vrimg format. There’s an issue with the vrimg to exr converter, which doesn’t work well with the current version of the vrimg format. Btw, you are using an outdated version of our plugin, you can find the latest version here: http://software.asgvis.com/index.php?option=com\_content&view=article&id=253&Itemid=53
has the vrimg2exr program been updated to handle vrimages from 1.49.01 -- or is it a compatibility issue in 1.49.01 that needs to be fixed in order for the current vrimg2exr program to work? 'twould be nice to have the extra channel info in raw format…
