Inspiration seem to keep me awake so i started a new projekt for myself.
And here is the first test of the scene.
And i am realy hoping to finish this one to the end of the weekend (if i won’t be pined down by the insane amount of work again)
PS - there might be something wrong with the collors right now cuz i did this on home pc on the 4:3 monitor wich i bought more than 10 years ago. And as always C&C wich i realy care about are very welcome.
The colored version looks nice. I think the soldier/robot (sorry, I am not familiar with the theme) should be more subtle, less saturated, maybe some reflectivity would help.
My advice would be (based on Juraj’s advice ) to go easier on the sharpening. If you look at real photos, the edges are usually soft. Of course that is unless you wish to introduce some sharpness on purpose, which seems to be popular in game/sci-fi themed works.
I think the composition could also be improved - the copter could be moved a little more towards center, the horizon could be moved up or down away from vertical center. But that would probably require some trial and error. I’m not really good at it.
I actualy dont know about composition, there is this thing that in warhammer thunderhawks very rarly fly near the surface for the surface so i want to keep the boarding angle and behighnd the sun position. But most probably i wil mooveit closer to the composition center.
And i cheked the texture on the character and there was some isues with red balance inside the bitmap so i just desaturated it and added some metalish reflections.
Aw and i finay made bonfire.
And i will try to keep my self from using sharpen on the final render XD
The pose will be the last thing to do cuz colegue will need to help me with that (model is not riged and he is quet buisy right now). I am planing to do at least 3 shots in this scene with different aspect ratio.
Agree about the variation, may be i will even use mask for the skale of the trees to add some more dynamic to the image.
By the way the interesting thing about this lithing set up is that does not have any enviroment ilumination at all. Fog+sun does all the job.
UPD - As idea may be add a couple of titans on the background and some explosions to amake a feeling of gong on battle. Just an idea. Or may be just one on the rhs.
UPD - I think final collorgrading will look something like T10
I have a wierdest idea to make a 1 min animation in this scene X_X if the rendertimes will not flick up to the time when all the things i wanted to improve will be improved.
