Release build Adv10903n50.exe
Max 5.1 unauthorised render slave.
Issue:
Distubutive Render (Spawner5.0) launhes the $_SRV_… on render salve but then just dissipears. This happens again and again and never engages.
Anyone???
Issue:
Anyone???
i believe this is due to instalation of DR problem try instaling it thru the wizard wich is located in max directory. DR needs it in order to work
Vray Spawner log
================ Starting new session ==========================
1: [2004/Dec/19|15:23:55] Got this module name: C:3dsmax5VRaySpawner50.exe
2: [2004/Dec/19|15:23:55] Got this INI file name: C:3dsmax5VRaySpawner.ini
3: [2004/Dec/19|15:23:55] *** ALERT! Could not open INI file: “C:3dsmax5VRaySpawner.ini”. Using defaults.
4: [2004/Dec/19|15:23:55] ========================== Ending session ==========================
0: [2004/Dec/19|15:36:34] ========================== Starting new session ==========================
1: [2004/Dec/19|15:36:34] Got this module name: C:3dsmax5VRaySpawner50.exe
2: [2004/Dec/19|15:36:34] Got this INI file name: C:3dsmax5VRaySpawner.ini
3: [2004/Dec/19|15:36:34] *** ALERT! Could not open INI file: “C:3dsmax5VRaySpawner.ini”. Using defaults.
4: [2004/Dec/19|15:36:34] ========================== Ending session ==========================
Running DR wizard
We have run the 5.0 DR wizard many times with no change in the errors in the pervious post
