BAC Mono
An image i created in 3DS Max & Corona 1.7.2 for the latest AutomotiveCGI contest - Low key lighting. I created 120m length of straight road and used Corona scatter to line it with kerb stones, a crash barrier (behind the camera), street lights, herras fencing, small bushes then larger bushes and well as grass over the built up verge to hide the horizon line. I animated the BAC Mono model (from Squir) using simple wire constraints between the Y position body and X axis wheel rotation. Lighting is Corona Sun/Sky with an HDRI in the visibility override slot and lighting from the street lights.
Not entirely happy with the final result, I didn’t have time to map the model properly so the Triplaner map for the carbon is a bit ropey in areas and the orange peel on the clear coat is too heavy.
Post work was in Photoshop.
C&C welcome
Well I think it looks really good, would love to see some wireframes.
