Bachelor's pad - Cubist/deconstructivist
I’ve been viewing this forum for a month now and read and viewed posts here while practicing.
This is my first post.
I want to learn more so I am posting these images here. Please comment and suggest.
Thank you.
Re: Bachelor’s pad - Cubist/deconstructivist
hi larje…
it’s a nice render, but i believe that you can really improve it a lot by finishing the model, with that i mean the louver element, cause i just see a lot of horizontal volumes without any visible support, also tv seems to have the same material than the wall, and i thing it’s floating.
it’s a very good illumination project, just try to reduce noise and you’re done :wink:
Thank you Omar for your comments.
Yes, this is still a work in progress. I still have to put materials on the tv, the sofa.
As for the louvres, there are two vertical members holding it anchored to the concrete behind, I am not sure why its not visible.
I am still experimenting what to tweak to reduce the noise. Any suggestions? I’ve heard about increasing subdivs. but i don’t know which subdiv needs to be increased.
Are you using DMC+LC?
If so, have you tried with IR+LC instead? Less noise problems and usually quicker.
Yes sir, I am using IR and LC.
