Back Burner Server - VFB not showing up
Hi Guys,
in last time in our node on renderfarm in backburner mode corona frame buffer is disappeared. I use 1.00.2 build .. and until 1 / 2 week ago all node work perfect for about one year. Now 12 node on 15 have this problem. i See node in remote mode
We try to erase xml in backburner folder, we try to erase all backburner folder, we try to uninstall and reinstall Backburner and Corona… nothing : Corona Frame buffer don’t appare
But on 3 node no problem…and naturally on our workstation no problem. I tnk we close one time the window on the node.. but i’m not sure.
We use max 2014 - win 7 on different node, xeon, I7, and so on.
Anyone have an idea ?
Hi, can you check this just to make sure everything is ok?
https://coronarenderer.freshdesk.com/support/solutions/articles/5000568650
Can you think of any difference between the nodes which work and those which don’t? For example different OS, different service packs installed, etc?
Can you save a copy of your scene, go to render setup and press “reset settings” and then see if the VFB still does not show up on some of the nodes?
Hi .. tnks for reply
Node are all the same OS Service pack and Corona installed.
If i send 100 frame of one scene ( one of 100 scene ) problem is the same : 3 node work good, and 12 no.. now i try to move one node in presidiated room and open directly with keyboard and try to undestand… VFB is check on .. i tnk is possibile i move window outside screen, but if i reset backburner will be good… and now no !
in next time i give u other info, now i’ve 100 frame in 5000 pix on render and i cant access on node :open_mouth:
tnks !
Add Note : if i send job in vray, framebuffer ok, if send job in corona with 3dmax framebuffer ok, if i send job in corona with coronaframebuffer, i can’t see window.
i installa lastest daily build nothing change
