Back to Beauty 16bit equivalent
Hi all
We use the Back to Beauty process for 32bit images in Photoshop, but wondered what the closest equivalent is in 16bit?
32bit
All set to - Linear Dodge ’Add’
With Lighting and GI being in their own folder
Reflection
Refraction
Specular
Self Illumination
Caustics
Atmosphere
Background
Is this a viable 16bit solution:
All set to Screen?
Reflect
Specular
Refract
Self Illumination
Caustics
Atmosphere
rawTotalLight
Diffuse
Background
Cheers
16-bit in photoshop is not linear, and screen isn’t a linear operation, so that definitely won’t work.
You could possibly do a workaround by making sure everything is imported into photoshop 16-bit with no gamma correction (or actually do a negative gamma correct on each layer, either way it should look too dark on your display), then using the same workflow as you would with 32-bit (same layers, Linear Dodge), and gamma correct the resulting beauty. It’s going to be quite a hack, not sure if that’d work.
