*those are not the paths for the files i just shortened them to c:\ for this post to make debuging easier
Always get :
error:could not find manager
I even got this message with this simple line :
cmdjob –jobname “Test” –manager 172.0.1.2 -netmask 255.255.0.0 -port 3234
I even try cmdjob –jobname “Test” –manager kdgdc02
Any ideas of what i’m doing wrong?
Can anyone test only that simple command:
cmdjob –jobname “test” –manager managername
I think the netmask is the problem… by default backburner netmask is 255.255.255.0
cmdjob is supposed to do that automatically. You said you shortened the paths. they are supposed to be in quotes tho, are they in the original command ?
On another note those IPs and netmasks look odd to me (wich doesnt mean they cant be :P)
Then the taskfile parameter is supposed to be -tasklist instead…that’s a typo in the ae example. read a bit above in the reference.
well it does work here. I know cause we’re using backburner to do netrendering with nuke. But we are on standard IP ranges (192.168.13.x) as well as standard subnetmask (255.255.255.0)
