Backburner animation failed to start due to missing map in Material Editor.
Maybe it`s just 3dsmax but just in case vray has a way around it. I recently had a backburner animation fail to start rendering because of a missing map in the material editor, it was a local texture the slaves didn`t have but wasn`t applied to anything in scene just a leftover in the Material Editor. I`m assuming textures are compiled at render time based on the scene (then cached ?), including files from the material editor when not actually used in scene doesn`t seem like a good use of memory/drive space given unused materials could have giant bitmaps in them leftover and a slave would have to load everything in before rendering whether it`s used or not. My animation wouldn`t even begin rendering, didn`t give just a warning just refused to start. Is this Vray or 3dsmax ? Can vray tell what`s being used in scene or does it have to just load everything to be sure ?
Using 2016.
thanks
anthonyh
Version 2016 of BB shouldn’t throws errors for missing maps unless the following environment variable is set:
3DSMAX_BACKBURNER_TREAT_MISSING_DLLS_MAPS_XREFS_AS_ERRORS=1.
More information about it here:
https://area.autodesk.com/blogs/max-station/n267-controlling-how-backburner-handles-missing-bitmaps-xrefs-and-plugins/
V-Ray also has a similar option called Check for Missing files available under the System Tab (Advanced preset):
Make sure both of those are disabled and see if it’s possible to complete the rendering even if some of the files are missing.
Will check thanks. Normally this doesn`t happen. Maybe one of those things has popped up in scene.?
