I read a lot about this shit of BB…
Often, in our office, we have this random error:
ERR 3dsmax adapter error : Error opening Max Job: C:\Users\PC02\AppData\Local\backburner\ServerJob\26 - Fiorine.xml.details.
ERR Launcher: Timed out executing command:“C:\3dsMax2015\3ds Max 2015\maxadapter.adp.exe” “-o” “ShutDown” “-l” “Info”
A lot of user, had our same problem, but it’s not clear the solution…
The bad thing is that it happens after 3-4-5 hours of render, not immediately! It’s a very big, break of ball.
Now, we are running BB Server on the not not as a service, and we use a mapped drive for all our asset:
Sorry but I do not know any certain solution. I don’t recall this being ever reported in our support. This is the first thing I thought of after I read that it happens after 3-5h because we had a slightly different report where BB would crash after ~200 passes or when zooming in/out in the VFB: the solution is to UNINSTALL (not just disable!) any antivirus software you are using. Here is the tiny article: https://coronarenderer.freshdesk.com/support/solutions/articles/5000637795
I doubt this will help, but why not give it a try…
No antivirus and no firewall on my slave. But, only in the main machine.
I’ll try to remove Avira on the master machine and see what it will happen…
Thanks =)
