Hi guys,
I dont know if my brain is melting or there is something wrong with vray/backburner.
I have pre-calced the lightcache. Saved that to a network path. Using from file (network path).
I am now calulating the irr map using a render node. I set to calc every 15 frames and have sent via backburner making sure that “do not render final image” is checked and “save” (in the max rollout) is not on. Also obviously, I am using multiframe incremental that is saving to a network path.
The problem is that the first frame is completed on the render node and then backburner throws an error saying it could not save to: c:/documents… This is the path for the max rollout, but it is not on. So im not sure what is happening.
Anyone got any ideas ?
