backburner perpetual render
having an issue here with backburner
the jobs save the images, but never register them as finished
and start rendering over and over again
max2016, corona 1.4 (same thing happened in 1.3)
saving EXR’s with user 2.2 gamma and no extra channels
the issue is elusive, i can’t figure any reason why it may happen
one day the file works fine the next it stops registering the network job completion
once it does that, though, it never goes back to being normal
if you have any insights, please share
thank you,
tony
What kind of limit are you using? (time/pass/noise?)
What kind of camera are you rendering from?
limit: pass
standard max camera with corona mod and camera correction on top
BTW “skip existing” band-aids the problem, the re-runs halt once they encounter existing images
however, a few version ago Autodesk broke yet another feature of backburner, and this time it was “skip existing” it doesn’t work with strips anymore, and strips is a very convenient way to quickly generate high res images on the render farm
old bug report; corona now uses totally reworked DR/net rendering system. I am moving this to resolved as it is probably no longer relevant. Feel free to create a new thread if you have any further similar problems
