backburner stopps
Dear corona team,
CORONA RENDER ENGINE
first of all I must say, that your renderer ist really stunning.
Just kicked off MR for a large scale project after testing your current Alpha.
Huge scene with lots of vegetation (build with forestpack) and the render time ist 1/10 of MR.
Wow!
BACKBURNER PROBLEM
But I figured out a problem with backburner which is really annoying:
When rendering the scene it occures that backburner stops.
Sometimes with error code sometimes without.
Mangager is sending the information, that the server is still working,
server application is running but it doesn’t do anything.
It happens no matter if server and manager apps or services are being used.
Rendering directly out of max works pretty well.
After restarting server and Manager they keep on rendering for a view frames and then stop again…
One error code is:
2015/01/26 09:07:37 INF Adapter returned unexpected code -2
Never had this with MR…
Do you have any idea what may cause this problem?
Thank you very much and with kind regards
Rue
