Vray Next CPU 4.2 update
So I have a large render going, 2 hours per frame.
Every time I come in in the morning I pause the render - and now, as I look back through the rendered frames, I see that there are a series of frames that are a fraction of the size of a proper rendered frame.
Could there be an issue with the way the VFB EXR sequence / progressive renderer / backburner is incorrectly registering a frame as “rendered” simply because it has has started and written a file to the hard drive?
Something is wrong, as I also notice that often using progressive renders, I get some frames that are totally not resolved to the same noise level as other files.
