Backburner ustable connectiom with servers
Hi all,
i have a worstation and two server that i am usung without problems in dr corona render, but when use buckburner the two servers becames unstable in connection and alternately lost connection with manager.
Someono know how can i solve it?
thank you.
Maybe there will be some clue in the BB logs? https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-find-and-analyze-your-backburner-error-logs.html
Thank you for answer,
that’s the log manager, but i don’t think i can find the problem.
Workstation is 192.168.1.25 where i star only the manager and not the server,
the render is spitted in 6 scan lines with the option to use only selected server.
2019/02/27 16:18:22 DBG Broadcast packet from 192.168.1.25
2019/02/27 16:18:22 DBG Client API Connection
2019/02/27 16:18:22 DBG TCP Connection from 192.168.1.25
2019/02/27 16:18:22 INF New client 192.168.1.25 added to client list
2019/02/27 16:18:43 DBG Registration request from muletto1-pc
2019/02/27 16:18:43 INF Successful registration from muletto1-pc
2019/02/27 16:19:04 DBG Registration request from muletto-w10
2019/02/27 16:19:04 INF Successful registration from muletto-w10
2019/02/27 16:19:14 INF Job ‘box’ added to the queue
2019/02/27 16:19:14 INF There is no valid server to process job ‘box’
2019/02/27 16:19:14 INF Job ‘box - Second Pass’ added to the queue
2019/02/27 16:19:14 DBG Starting job assignment thread for ‘muletto1-pc’
2019/02/27 16:19:14 DBG Starting job assignment thread for ‘muletto-w10’
2019/02/27 16:19:14 INF Sending instructions for job ‘box’ to muletto1-pc
2019/02/27 16:19:14 INF Sending instructions for job ‘box’ to muletto-w10
2019/02/27 16:19:14 DBG End TCP Connection with wd-lorenzo
2019/02/27 16:19:15 DBG Job ‘box’ received by muletto-w10
2019/02/27 16:19:15 INF There is no valid server to process job ‘box - Second Pass’
2019/02/27 16:19:15 DBG Job ‘box’ received by muletto1-pc
2019/02/27 16:19:37 DBG Application is up from muletto-w10.
2019/02/27 16:19:37 DBG Assign task 1 to muletto-w10
2019/02/27 16:19:48 DBG Application is up from muletto1-pc.
2019/02/27 16:19:48 DBG Assign task 0 to muletto1-pc
2019/02/27 16:20:04 ERR Server muletto1-pc did not acknowlege receiving new task.
2019/02/27 16:20:04 ERR Job ‘box’ (Autodesk 3ds Max 2016 (64-bit)) failed for muletto1-pc
2019/02/27 16:20:04 DBG Task 0 error from muletto1-pc on box
2019/02/27 16:20:04 ERR Error message: Task assignment timeout
2019/02/27 16:20:04 DBG Server muletto1-pc is returning 1 task(s)
2019/02/27 16:20:04 WRN Server muletto1-pc flagged as failed for job ‘box’
2019/02/27 16:20:09 WRN Could not broadcast REMOVE_SERVER request on lo: Tentativo di operazione del socket verso una rete non raggiungibile.
2019/02/27 16:20:09 DBG BB Wiretap Server disconnecting…
2019/02/27 16:20:09 DBG End TCP Connection with wd-lorenzo (code: 0)
2019/02/27 16:20:09 DBG Network Manager Shutdown Initiated
2019/02/27 16:20:09 DBG Sent Manager Shutdown notice to muletto-w10
2019/02/27 16:20:09 DBG Sent Manager Shutdown notice to muletto1-pc
2019/02/27 16:20:09 ERR Error accepting connection: Tentativo di operazione su un elemento diverso dal socket. (0x2736).
..for me should be very important use backburner so i can render without the workstation, i hope in future corona dr will have that feature.
Corona dr has also the great advantage to resolve the local path automatically.
Please also post the corresponding …\network\max.log part in that timestamp range. Has your setup ever worked correctly with other scenes?
Good Luck
It has never worked.
As soon as possible i will post the corrisponding log of the servers.
you mean the log of servers?
Yes, the log of the rendering max instance on the servers. And because of
What do you see in the Backburner Server window log when exactly this happens? You could increase log level by going to Edit → log setting and tick “Debug” and “Debug Extended” to get all information. I’ll attach a screenshot from a successfull task of a node for you to compare (funny that they still not have fixed that typo in the log message btw.)
Somehow it reads as if the BB-server could not save the required files locally? They go to AppData\Local\backburner\ServerJob from the user running the Backburner server usually. You could check if files arrive there when the server gets a job assigned in that directory.
Then you have to setup Backburner / network correctly first of all. Some hints:
  • Have you tried to disable the firewalls temporarily?
  • Make sure, the nodes (“servers”) have only exactly one network adapter active, there are quite a lot boards which have two. Disable the unused one.
  • Disable IPv6 on that interface in use (untick TCP/IPv6 in adapter settings), on manager and at least one node to test
  • Make sure you have a matching and updated Backburner version installed
But I guess the BB server log (not the manager log) will reveal something useful here.
Good Luck
Solved,
the simplest solution, was the advanced antivirus firewall.
disabling it and disabling the windows defender only for private lan it works.
I know that is not the best solution, but it’s really dangerouse disable the private lan firewall?
