Hey guys, I hope someone can help. Just finished a large render and we have rogue render node spitting out garbage frames:( I need to delete the frames and re render the bad ones. I tried using a script from script spot which promised (well not promised) to delete any frames from the rogue node but it didn’t work. I manually deleted some and checked 'skip existing ’ and set the job off again with backburner.
I’m guessing that skip existing does not work with the vray frame buffer and elements?
I’m in a world of pain here so if anyone has any ideas that can help me rescue this, that would be amazing ![]()
Hm, not sure how to do that with backburner except to list all the wrong frames in the render dialog before submitting. Other render managers can generally handle this better.
Thanks for the reply, so does the skip existing feature not detect the files written by the frame buffer?
If you specified the render output in the Common tab of the render setup dialog, it will work. If you specified the output in the V-Ray VFB settings, it will not.
…sobs quietly over keyboard ![]()
