backburner
hello all
I have a problem with the path to backburner!
When I click the render button in max, a message appears:
PROBLEM: backburner not found message when clicking Render button:
Cannot network render. Backburner not found or not installed.
This error dialog appears because the path to backburner is either not set properly in the Path environment variable or backburner in missing all together.
SUGGESTION
Verify that the Path variable is set properly and make sure you’ve installed the latest version of backburner.
I would like to set the paths right, but where?
thanks in advance
best regards
themaxxer
if you on windows xp righ click on my computer icon, then go manage under environment variable set the path to your back burner, reboot system and try that
