Background Image and Metal Materials Transparency
Greetings,
I have noticed, and cannot figure out any solution, that applying a background image as environment causes any metal material transparent.
Attached-please-find the SU file.
I will deeply appreciate any elucidation, solution, piece of advice. Thank you in advance
Hello Artur,
Try adding Reflection and Refraction overrides as well. Here is an example:
Similar case was discussed in this forum thread.​
Hello, I do thank you very much.
