Background image option in VFB
I tested the background image option in the VFB. It is to dark.
Visible in the overlay comparison with original image (jpg)
Can this be adjusted somehow?
edit:
ok, i see if i open a new project, the colourmanagment is set to ACES. Why not srgb (linear workflow)?
You are probably using ACES color management mode in Cinema 4D, right? That basically applies a LUT (color transform) to anything you render. You can disable it if you need to get exactly the same colors/brightness as in a directly viewed jpg image - https://support.maxon.net/hc/en-us/articles/21984158699292-Cinema-4D-R2026-Color-Management
Yes, but why is it not set to linear workflow by default? did not realize this before…
Thanks for the link, i will read and hopefully understand it :laughing:
Both Cinema 4D and 3ds Max use ACES workflow by default (globally, not just with Corona) and that is not our decision. :slight_smile:
My opinion, and it’s not only mine, is that ACES workflow should only be used when you really need it. Otherwise you can use the simpler sRGB / gamma workflows, and if you like the ACES appearance, you can simply enable the ACES OT operator in the Corona VFB.
You can also save your own defaults, use startup scenes, etc.
Thanks for the clarification. I see it the same way, i never use the ACES workflow nor the ACES OT operator in VFB. I always use the Reinhard highlight compression.
