Is the C4D’s Background Image Plate supported in Corona?
If you mean the Background object, then not yet. Although we’re planning to support it later on
You should be able to achieve the same using the environment settings though.
…you just opened pandora’s question box…
great to hear that!
I’ve been playing around with the environment settings and till now I just get quite pixelated backgrounds. Will keep on playing around.
Here I found some more info on the subject: https://forum.corona-renderer.com/ Background Image Plate #msg107220
