Rendered and save a file in PSD later but I did not saw background layer, no idea what i did wrong. I did test new file… its saving but not job file… any idea what I did wrong in that…?
thanks.
thanks.
ahhhhhh…! FOUND.
If I do some setting in IR “Post”… from picture viewer it does not save background layer in psd.
To get background layer… don’t do any setting in Post, keep it disable, render again and save layered psd, you will get background layer.
Process is like this or its a bug…?
Thanks.
No one…?
No one to update me…?
Hi Imran,
I will look on it later today.
Nikola
Hi Nikola,
Any update…?
Many fixes but this unknown bug missed to fix…!
Its old but still its not fixed why background layer disappear while doing post effect setting in IR…?
This old post… still remains unknown…!
Officially Corona released… hotfix released… may be soon hotfix 2… but this its not fixed.
I did posting also at bug report forum but that not found and it was with video.
Thanks.
Do you also get the same result with Cinema’s standard renderer?
C4d standard never tried but in Vray it was fine… no issue…!
This occasionally happens with me too.
When I save from PV a layered psd - occasionally when I open the file the mask passes etc are there, but the ‘beauty’ background isn’t.
It’s particularly odd as the psd thumbnail previews with the beauty image.
Normally I just save it again and that solves it.
I’ve been meaning to mention this this for a while, but wanted to see if I could reproduce it on demand first.
Tried all that, Still works for me.
Aha!
Yep - I’ve just tried again. Using a file that I’ve had no problems with previously.
I rendered it until it was finished. Then tweaked and toggled the tone mapping settings in the corona tag of the Picture Viewer.
Then saved out as a layered 32bit psd.
The thumbnail preview shows the image, but the opened PSD has the ‘background’ image missing (see attached).
Using the Corona 3 full release, C4D 20, mac, latest version of Ps.
This might very well be a Mac issue if that’s the case. Unless there are some Windows users here that have experienced the same thing?
Here is a small video again.
