background on vray 1.48.89
Hi again! I was just wondering why every time I put a background image on the vray option, the image is too large even though it is set to environment. I tried resizing it but the image is being stretch and distorted. Any advise that you can give? thanks a lot and I really appreciate your response! :slight_smile:
Re: background on vray 1.48.89
Are you using a spherical hdri? Maybe it’s some other type? Are you using an hdri at all? Is it just a regular rectangular image? Would it be possible for you to post the image so we can see what you’re working with? Can I type any more questions?
I guess that you are using an HDRI as Devin asked. There no way to control the scale of the HDRI. The only thing that you can do with the HDRI is us the repeat option, but this is not the solution. The solution is find a zoom out HDRI. When I said zoom out HDRI I’m talking of an HDRI that was taken from a larges distance, so that the area that should be in the background is smaller.
Hi sir dkendig! regarding your questions, im not quite sure about the type of image it is but i think it is a spherical image and it is specified as bg so it is intended for background. I want to show the image but I don’t know how to post one sir.
http://forum.asgvis.com/index.php?topic=2043.0
