background plane, alpha
I would like to use a plane in the scene for a background. What to I have do setup this plane that I have this excluded from the alpha, but still visible in the rendering?
Thanks for help
NooM
Select the object, right click, VRay properties and change the Alpha contribution to 0.
Dan
thank you!!! :slight_smile:
Actually, -1.0 I believe is what you want, not 0?
Setting the background’s alpha to 0 or -1 would probably do the same thing in this case.
As I understand it, if you just need the background plane not to show in the alpha channel then setting the alpha contribution to 0 will do that. If you have an foreground object in front of a background plane and you want a ‘hole’ cut into the background plane’s alpha where the object is then you would set the object’s alpha contribution to -1.
Dan
