Background Render Element.
I cant seem to get the background render element to render out. If you use the vray sky in your enviroment slot will it cause vray not to render out the enviroment. each time it renders out a black image. Anyone know what im doing wrong. Thanks Gadzooks
working okay for me. The vraysky is showing properly in your standard frame buffer?
percy thanks for responding. The RGB Channel shows the vray sky during the rendering. But the Vray Background channel will not save out the background. It just saves out a completley black image.
If you do a test in a simple scene with a grey background, does it work as expected?
Vlado i will check.
RGB
VRAY Background Render Element
Im useing the default max frame buffer. Also have tried the Vray’s VFB.
It’s not the background you need. It’s the refraction channel you want since it’s seen refracted through the glass.
