Im aware of the weird shadow artifact a background image can cause - is there a definitive solution as everything i am trying doesnt seem to work. I am trying to get interior reflective elements to reflect what is behind the camera (in this case, an outdoor area). I have put a plane there and applied a light material to it within the rayswitch but notning seems to work - please help.
Hi, if you are looking for a solution which would just make it work without sacrificing any of the effects, then unfortunately there is no such thing.
One workaround is to use a different material for reflections and all the other ray types: https://forum.corona-renderer.com/geosphere as background#msg181607
But this will change the appearance of your scene (the reflections will not look as you would ideally expect them).
Thanks - this is a major issue for me and many of my colleagues as its often used on 90% of our interiors ton control reflections - is there a fix for it in the pipeworks?
We are aware that this is a major issue, but unfortunately it would be extremely complex to fix. It is properly logged and we will possibly attempt to fix it at some point, but can’t provide any time frame, sorry.
